Какие турбины на каких Эво стоят в стоке
• Страница 2 из 3 • 1, 2, 3
Многие спрашивают и ищут инфу - что и где стоит в стоке
Вот нашёл инфу
Evo I-X stock Turbocharger Specs
Evolution 1
Turbo = TDO5H-16G-7
p/n = 49168-01450
Nozzle Area (cm2) = 7
TD05H turbine = Inconel (steel alloy)
Compressor = Aluminium
Inducer = 48.3mm
Exducer = 68mm
Evolution 2
Turbo = TDO5H-16G-7
p/n = 49168-01450
Inducer = 48.3mm
Exducer = 68mm
Evolution 3
Turbo = TD05H-16G6-7
p/n = 49178-01470
Inducer = 48.3mm
Exducer = 68mm
Reverse rotation turbos and twin scroll turbine housing from EVO4.
Evolution 4
Turbo = TD05HR-16G6-9T
p/n = 49178-01510
Nozzle Area (cm2) = 9
TD05HR turbine = Inconel (steel alloy)
Compressor 16G6 = Aluminium
Inducer = 48.3mm
Exducer = 68mm
Turbine housing = twin flapper
Evolution 5
Turbo = TD05HR-16G6-10.5T (GSR)
p/n = 49178-01520
Turbo = TD05HRA-16G6-10.5T (RS)
p/n = ?
Nozzle Area (cm2) = 10.5
TD05HR turbine = GSR Inconel (steel alloy)
TD05HRA turbine = RS Titanium alloy
Inducer = 48.3mm
Exducer = 68mm
Evolution 6
p/n = 49178-01550
Turbo = TD05HRA-16G6-10.5T (RS/RS2)
p/n = 49178-01560
TD05HR turbine = GSR - Inconel (steel alloy)
Inducer = 48.3mm
Exducer = 68mm
Evolution 6.5 : Tommi Makinen Edition
Turbo = TD05RA-15GK2-10.5T (GSR)
p/n = 49178-01570
Turbo = TD05HRA-16G6-10.5T (RS/RS2) (Note: OZ TME)
p/n = 49178-01560
TD05HRA turbine = Titanium alloy for both RS/RS2/GSR!
Inducer = 48.3mm
Exducer = 68mm
Compressor 15GK2 = Aluminium
Inducer = 49.3mm
Exducer = 65mm
Evolution 7
Turbo = TD05HR-16G6-9.8T (GSR)
p/n = 49178-01570
Turbo = TD05HRA-16G6-9.8T (RS/RS2)
p/n = 49178-01580
Nozzle Area (cm2) = 9.8
TD05HRA turbine = RS/RS2 = Titanium alloy
Inducer = 48.3mm
Exducer = 68mm
Evolution 7 GTA
Turbo = TD05HR-15GK2-9.0T
p/n = 49378-01500
Nozzle Area (cm2) = 9.0
TD05 Turbine = Inconel (steel alloy)
Inducer = 49.3mm
Exducer = 65mm
Evolution 8
Turbo = TD05HR-16G6-9.8T (GSR / USDM / ADM)
p/n = 49378-01520 (twin flapper)
Turbo = TD05HRA-16G6-9.8T (RS/RS2 & NZDM)
p/n = 49378-01510
p/n = 49378-01540 (ADM EVO8 single flapper)
TD05HR turbine = USDM EVO 8 & JDM GSR =Inconel (steel alloy),
TD05HRA turbine = RS Titanium alloy.
Inducer = 48.3mm
Exducer = 68mm
Turbine housing = twin flapper USDM
Evolution 8MR aka "8.5"
TD05HR-16G6-10.5T
p/n = 49378-01560
TD05HRA-16G6-10.5T (Ti Alloy option)
p/n = 49378-01550
Inducer = 48.3mm
Exducer = 68mm
Turbine housing = single flapper
Evolution 9
p/n = 49378-01580
Turbo = TD05HRA-16G6mC-10.5T (RS)
p/n = 49378-01571
p/n = 49378-01570
TD05HR turbine GSR = Inconel (steel alloy),
TD05HRA turbine RS = Titanium alloy
Compressor 16G6 = Aluminium (GSR)
Inducer = 48.3mm
Exducer = 68mm
Compressor 16G6mC = Magnesium (RS)
Inducer = 48.3mm
Exducer = 68mm
Back to "normal" rotation turbos from EVOX.
Evolution X
Turbo = TD05H-152G6-12T (GSR)
p/n = 49378-01640
p/n = 49378-01641
Turbo = TD05HA-152G6-12T (GSR)
p/n = 49378-01631 (Ti Alloy)
Nozzle Area (cm2) = 12
TD05HA turbine = Titanium alloy
Compressor 152G6 = Aluminium
Inducer = 47mm
Exducer = 68mm
NOTE: TD05H & TD05HR & TD05HRA turbine wheel all models
Inducer = 56mm
Exducer = 49.2mm
Вот нашёл инфу
Evolution 1
Turbo = TDO5H-16G-7
p/n = 49168-01450
Inducer = 48.3mm
Exducer = 68mm
Evolution 2
Turbo = TDO5H-16G-7
p/n = 49168-01450
Inducer = 48.3mm
Exducer = 68mm
Evolution 3
p/n = 49178-01470
Inducer = 48.3mm
Exducer = 68mm
Evolution 4
p/n = 49178-01510
Inducer = 48.3mm
Exducer = 68mm
Evolution 5
p/n = 49178-01520
p/n = ?
Inducer = 48.3mm
Exducer = 68mm
Evolution 6
p/n = 49178-01550
p/n = 49178-01560
Inducer = 48.3mm
Exducer = 68mm
p/n = 49178-01570
p/n = 49178-01560
Inducer = 48.3mm
Exducer = 68mm
Inducer = 49.3mm
Exducer = 65mm
Evolution 7
p/n = 49178-01570
p/n = 49178-01580
Inducer = 48.3mm
Exducer = 68mm
Evolution 7 GTA
p/n = 49378-01500
Inducer = 49.3mm
Exducer = 65mm
Evolution 8
p/n = 49378-01510
Inducer = 48.3mm
Exducer = 68mm
TD05HR-16G6-10.5T
p/n = 49378-01560
p/n = 49378-01550
Inducer = 48.3mm
Exducer = 68mm
Evolution 9
p/n = 49378-01580
p/n = 49378-01571
p/n = 49378-01570
Inducer = 48.3mm
Exducer = 68mm
Inducer = 48.3mm
Exducer = 68mm
Evolution X
p/n = 49378-01640
p/n = 49378-01641
Inducer = 47mm
Exducer = 68mm
Inducer = 56mm
Exducer = 49.2mm
Re: Какие турбины на каких Эво стоят в стоке
Юр, это про магниевую была речь! Ну собственно и в эту никто не советует дуть 2кг) Полтора для нее само ништяк!
Блииин, дайте 25 рублей. хочу такую турбу
keurogeo - Клубень Stage 2
А где надыбал? не эта часом? http://injapan.ru/auction/j291802203.html
georg1970 писал(а):А где надыбал? не эта часом? http://injapan.ru/auction/j291802203.html
Это второй вариант, а еще один мне во Владе предложили.
На иджапан она одна такая вроде бы
интересно такая турба надувает больше лс по сравнению с обычной 10.5Т? или просто спул раньше?
boris - Клубень Stage 1
Просто спул раньше.
Ром, у нее компрессорная часть чуть больше. Она надует больше, чем обычная http://www.evoscan.com/technical-vehicl ... erformance
Хмм... Вроде же 15.5 меньше чутка чем 16?))))
вроде да)) значит, чуть меньше))
Что-то зачастили в последнее время TD05HRA-155G6C-10.5T... В этом году как минимум 3 штуки продавались в Японии. Не устоял, купил себе одну.
У нее правда так хорошо со спулом как пишут или стоило взять FP White?
- Chatty
У меня еще с япы стояла турбина Greddy TD05H - 18G (49178-05090). Хорошо валила. Но довольно быстро засопливила. Вроде как редкость?
- Realex
Нашёл старое фото сравнения турбы от 9МР РС и 5
Если кому-то понадобится, то:
TD05HRA-155G6C-10.5T (Ti/Inconel)
p/n = 49378-01600
1515A130
Evolution IX MR GSR
TD05HRA-155G6mC-10.5T (Ti/Mg)
p/n = 49378-01590
1515A128
Evolution IX MR RS
p/n = 49378-01600
1515A130
Evolution IX MR GSR
p/n = 49378-01590
1515A128
Evolution IX MR RS
- Chatty
расшифровка, вдруг пригодится кому =)
Итак, возьмем для примера турбину TD05HRA-155G6mC-10.5T
1. TD05H - тип турбины. Чем больше число, тем больше турбина
2. R - на турбинах до Evo4 не применяется
3. А - турбинное колесо изготовлено из сплава титана
4. 155G - размеры компрессорной части (холодная часть)
5. m - компрессорное колесо изготовлено из сплава магния
6. 10.5 - размеры турбинной части (горячая часть)
7. Т - твинскрольный тип турбины (Evo4 и далее)
Почему J-pipe у эво7-8 и эво9 разные - потому что разные размеры холодной части
А турбину ЭВО Х кто нибудь ставил? И возможно ли?
votblin - Клубень Stage 3
- Тел.: +79180616441
Ставили - но отзыва так и не дождались.
Костя 4g64 ставил на Эво - говорит спул просто космический
По параметрам она должна быть примерно как 9
Сегодня как-то получилось на заблокированном ГТ на 5ой раздуть в горочку турбу до бара на 2200об. На 2000об у меня 0.6.
Но байпас начинает открываться при таких условиях, особенно в мороз, ибо дроссель сильно закрыт. То бишь перед дросселем давление сильно больше )
49178-01520
TD05HR-16G6-10.5T
980314298
турба от пятёрки, но размеры как у девятки получается...кто вкурсе что за зверь?
TD05HR-16G6-10.5T
980314298
стоковая турбина от 5 гср.
То что она от пятерки это понятно...Я имею ввиду по производительности в сравнении с девяткой такая турба что выдаст по факту?
Небо и земля
